inria-00321485, version 2
Non-linear CCA and PCA by alignment of local models
Jakob Verbeek
1Sam Roweis 2Nikos Vlassis
a, 1
Seventeenth Annual Conference on Neural Information Processing Systems (NIPS '03) (2003) 297--304
Résumé : We propose a non-linear Canonical Correlation Analysis (CCA) method which works by coordinating or aligning mixtures of linear models. In the same way that CCA extends the idea of PCA, our work extends recent methods for non-linear dimensionality reduction to the case where multiple embeddings of the same underlying low dimensional coordinates are observed, each lying on a different high dimensional manifold. We also show that a special case of our method, when applied to only a single manifold, reduces to the Laplacian Eigenmaps algorithm. As with previous alignment schemes, once the mixture models have been estimated, all of the parameters of our model can be estimated in closed form without local optima in the learning. Experimental results illustrate the viability of the approach as a non-linear extension of CCA.
- a – Technical University of Crete
- 1 : Instituut voor Informatica (IvI)
- Universiteit van Amsterdam
- 2 : Department of Computer Science
- University of Toronto
- Domaine : Informatique/Apprentissage
- Versions disponibles : v1 (03-02-2011) v2 (05-04-2011)
- inria-00321485, version 2
- http://hal.inria.fr/inria-00321485
- oai:hal.inria.fr:inria-00321485
- Contributeur : Jakob Verbeek
- Soumis le : Mardi 5 Avril 2011, 14:54:32
- Dernière modification le : Mardi 5 Avril 2011, 15:36:38
Documents associés
Exporter
