Efficient greedy learning of Gaussian mixture models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Neural Computation Année : 2003
Jakob Verbeek
Nikos Vlassis
  • Fonction : Auteur
  • PersonId : 853678
This article concerns the greedy learning of gaussian mixtures. In the greedy approach, mixture components are inserted into the mixture one after the other. We propose a heuristic for searching for the optimal component to insert. In a randomized manner, a set of candidate new components is generated. For each of these candidates, we find the locally optimal new component and insert it into the existing mixture. The resulting algorithm resolves the sensitivity to initialization of state-of-the-art methods, like expectation maximization, and has running time linear in the number of data points and quadratic in the (final) number of mixture components. Due to its greedy nature, the algorithm can be particularly useful when the optimal number of mixture components is unknown. Experimental results comparing the proposed algorithm to other methods on density estimation and texture segmentation are provided.
verbeek03neco.pdf (597.25 Ko) Télécharger le fichier
Format : Figure, Image
inria-00321487 , version 1 (16-02-2011)
Jakob Verbeek, Nikos Vlassis, Ben Krose. Efficient greedy learning of Gaussian mixture models. Neural Computation, 2003, 15 (2), pp.469-485. ⟨10.1162/089976603762553004⟩. ⟨inria-00321487⟩
222 Consultations
1394 Téléchargements
