A k-segments algorithm for finding principal curves
We propose an incremental method to find principal curves. Line segments are fitted and connected to form polygonal lines (PLs). New segments are inserted until a performance criterion is met. Experimental results illustrate the performance of the method compared to other existing approaches.
10.1.1.20.291.pdf (183.66 Ko)
Télécharger le fichier
Format : Figure, Image
