Fast nonlinear dimensionality reduction with topology preserving networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
Jakob Verbeek
Nikos Vlassis
  • Fonction : Auteur
  • PersonId : 853678
We present a fast alternative for the Isomap algorithm. A set of quantizers is fit to the data and a neighborhood structure based on the competitive Hebbian rule is imposed on it. This structure is used to obtain low-dimensional description of the data by means of computing geodesic distances and multi dimensional scaling. The quantization allows for faster processing of the data. The speed-up as compared to Isomap is roughly quadratic in the ratio between the number of quan- tizers and the number of data points. The quantizers and neighborhood structure are use to map the data to the low dimensional space.
verbeek02esann.pdf (129.28 Ko) Télécharger le fichier
Format : Figure, Image
inria-00321500 , version 1 (16-02-2011)
  • HAL Id : inria-00321500 , version 1
Jakob Verbeek, Nikos Vlassis, Ben Krose. Fast nonlinear dimensionality reduction with topology preserving networks. 10th Eurorean Symposium on Artificial Neural Networks (ESANN '02), Apr 2002, Bruges, Belgium. ⟨inria-00321500⟩
100 Consultations
211 Téléchargements
