Efficient greedy learning of Gaussian mixtures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
Jakob Verbeek
Nikos Vlassis
  • Fonction : Auteur
  • PersonId : 853678
Ben Krose
  • Fonction : Auteur
  • PersonId : 853721
We present a deterministic greedy method to learn a mixture of Gaussians. The key element is that we build-up the mixture component-wise: we start with one component and then add new components one at a time and update the mixtures in between the component insertions. Instead of solving directly a optimization problem involving the parameters of all components, we replace the problem by a sequence of component allocation problems involving only the parameters of the new component. Included are experimental results obtained from extensive tests on artificially generated data sets. The new learning method is compared with the standard EM with random initializations approach as well as to other existing approaches to learning Gaussian mixtures.
verbeek01bnaic.pdf (168.9 Ko) Télécharger le fichier
Format : Figure, Image
inria-00321510 , version 1 (16-02-2011)
  • HAL Id : inria-00321510 , version 1
Jakob Verbeek, Nikos Vlassis, Ben Krose. Efficient greedy learning of Gaussian mixtures. The 13th Belgian-Dutch Conference on Artificial Intelligence (BNAIC'01), Oct 2001, Amsterdam, Netherlands. pp.251--258. ⟨inria-00321510⟩
68 Consultations
82 Téléchargements
