inria-00322331, version 4
Using Structural Recursion for Corecursion
Yves Bertot
1Ekaterina Komendantskaya
1
Types 2008 5497 (2008) 220-236
Résumé : We propose a (limited) solution to the problem of constructing stream values defined by recursive equations that do not respect the guardedness condition. The guardedness condition is imposed on definitions of corecursive functions in Coq, AGDA, and other higher-order proof assistants. In this paper, we concentrate in particular on those non-guarded equations where recursive calls appear under functions. We use a correspondence between streams and functions over natural numbers to show that some classes of non-guarded definitions can be modelled through the encoding as structural recursive functions. In practice, this work extends the class of stream values that can be defined in a constructive type theory-based theorem prover with inductive and coinductive types, structural recursion and guarded corecursion
- 1 : MARELLE (INRIA Sophia Antipolis)
- INRIA
- Domaine : Informatique/Logique en informatique
Informatique/Informatique et théorie des jeux - Mots-clés : Constructive Type Theory – Structural Recursion – Co-inductive types – Calculus of Constructions
- Versions disponibles : v1 (17-09-2008) v2 (18-09-2008) v3 (22-09-2008) v4 (23-03-2009)
- inria-00322331, version 4
- http://hal.inria.fr/inria-00322331
- oai:hal.inria.fr:inria-00322331
- Contributeur : Yves Bertot
- Soumis le : Lundi 23 Mars 2009, 13:21:02
- Dernière modification le : Lundi 23 Mars 2009, 13:35:35
Documents associés
Exporter
