Monitoring SIP traffic using Support Vector Machines - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
In this paper, we propose a novel online monitoring approach able to distinguish between attacks and normal activity in SIP based Voice over IP environments. We demonstrate the efficiency of the approach even in presence of very limited data sets for the learning phase. The solution builds on the monitoring of a set of 38 features in VoIP flows and on Support Vector Machines for the classification part. We validate our proposal through large offline experiments performed over a mix of real world traces from a large VoIP provider and attacks locally generated on our own testbed. Results show high accuracy to detect SPIT and flooding attacks and promising performance for an online deployment are measured.
main.pdf (631.74 Ko) Télécharger le fichier
inria-00325290 , version 1 (27-09-2008)
  • HAL Id : inria-00325290 , version 1
Mohamed Nassar, Radu State, Olivier Festor. Monitoring SIP traffic using Support Vector Machines. 11th International Symposium on Recent advances in intrusion detection - RAID 2008, Sep 2008, Boston, United States. pp.311-330. ⟨inria-00325290⟩
186 Consultations
411 Téléchargements
