On the Integration of a TSP Heuristic into an EA for the Bi-objective Ring Star Problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
This paper discusses a new hybrid solution method for a bi-objective routing problem, namely the bi-objective ring star problem. The bi-objective ring star problem is a generalization of the ring star problem in which the assignment cost has been dissociated from the cost of visiting a subset of nodes. Here, we investigate the possible contribution of incorporating specialized TSP heuristics into a multiobjective evolutionary algorithm. Experiments show that the use of this hybridization scheme allows a strict improvement of the generated sets of non-dominated solutions.
liefooghe.hm2008.pdf (256.04 Ko) Télécharger le fichier
inria-00326372 , version 1 (03-10-2008)
Arnaud Liefooghe, Laetitia Jourdan, Nicolas Jozefowiez, El-Ghazali Talbi. On the Integration of a TSP Heuristic into an EA for the Bi-objective Ring Star Problem. International Workshop on Hybrid Metaheuristics (HM 2008), 2008, Malaga, Spain. pp.117--130, ⟨10.1007/978-3-540-88439-2_9⟩. ⟨inria-00326372⟩
181 Consultations
363 Téléchargements
