s'authentifier
version française rss feed
inria-00326712, version 1
Simultaneous learning of motion and appearance
Karel Zimmermann 12, Tomas Svoboda 1, Jiri Matas 1
The 1st International Workshop on Machine Learning for Vision-based Motion Analysis - MLVMA'08 (2008)
Résumé : A new learning method for motion estimation of objects with significantly varying appearance is proposed. Varying object appearance is represented by a low dimensional space of appearance parameters. The appearance mapping and motion estimation method are optimized simultaneously. Appearance parameters are estimated by unsupervised learning. The method is experimentally verified by a tracking application on sequences which exhibit strong variable illumination, non-rigid deformations and self-occlusions.
  • Domaine : Informatique/Vision par ordinateur et reconnaissance de formes
  • inria-00326712, version 1
  • oai:hal.inria.fr:inria-00326712
  • Contributeur :
  • Soumis le : Dimanche 5 Octobre 2008, 12:23:12
  • Dernière modification le : Lundi 6 Octobre 2008, 09:20:34
tous les articles de la base du CCSd...
