From Local Temporal Correlation to Global Anomaly Detection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
In this paper, we propose a novel framework tailored towards global video behaviour anomaly detection in complex outdoor scenes involving multiple temporal processes caused by correlated behaviours of multiple objects. Specifically, given a complex wide-area scene that has been segmented automatically into semantic regions where behaviour patterns are represented as discrete local atomic events, we formulate a novel cascade of Hidden Markov Models to model behaviours with complex temporal correlations by utilising combinatory evidences collected from local atomic events. Using a cascade configuration not only allows for accurate detection of video behaviour anomalies, more importantly, it also improves the robustness of the model in dealing with the inevitable presence of errors and noise in the behaviour representation resulting less false alarms. We evaluate the effectiveness of the proposed framework on a real world traffic scene. The results demonstrate that the framework is able to detect not only anomalies that are visually obvious, but also those that are ambiguous or supported only by very weak visual evidence, e.g. those that can be easily missed by a human observer.
mlvma08_submission_12.pdf (4.41 Mo) Télécharger le fichier
inria-00326724 , version 1 (05-10-2008)
  • HAL Id : inria-00326724 , version 1
Chen Change Loy, Tao Xiang, Shaogang Gong. From Local Temporal Correlation to Global Anomaly Detection. The 1st International Workshop on Machine Learning for Vision-based Motion Analysis - MLVMA'08, Oct 2008, Marseille, France. ⟨inria-00326724⟩
Collections
MLVMA08
238 Consultations
166 Téléchargements
