LFW Results Using a Combined Nowak Plus MERL Recognizer
MERL's recognizer has two major components. The first is an aligner whose input is any arbitrary image and whose output is a cropped and rectified face if the image contains a face. The second is a comparator whose input is two aligned faces and whose output is a similarity score. The comparator is described in detail in [3].
