Shape from Probability Maps with Image-Adapted Voxelization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Jordi Salvador
  • Fonction : Auteur
Josep R. Casas
  • Fonction : Auteur
This paper presents a Bayesian framework for Visual Hull reconstruction from multiple camera views with a 3D sampling scheme based on an irregular 3D grid, which becomes regular once projected onto the available views. The probabilistic framework consists in establishing a foreground probability for each pixel in each view rather than segmenting in order to obtain binary silhouettes of the foreground elements. Next, a Bayesian consistency test labels the occupancy of each image-adapted 3D sample. The proposed method, using image-adapted 3D sampling in the Bayesian framework, is compared to a shape-from-silhouette implementation with image-adapted voxelization, where the input data are binary silhouettes instead of probability maps; we also compare its performance to a state-of-the-art method based on regular 3D sampling with binary silhouettes and SPOT projection test.
1569139894.pdf (309.15 Ko) Télécharger le fichier
inria-00326773 , version 1 (05-10-2008)
  • HAL Id : inria-00326773 , version 1
Jordi Salvador, Josep R. Casas. Shape from Probability Maps with Image-Adapted Voxelization. Workshop on Multi-camera and Multi-modal Sensor Fusion Algorithms and Applications - M2SFA2 2008, Andrea Cavallaro and Hamid Aghajan, Oct 2008, Marseille, France. ⟨inria-00326773⟩
Collections
M2SFA2
56 Consultations
190 Téléchargements
