State-Based Visibility for 3D Reconstruction from Multiple Views - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Estimating visibility is one of the most important steps for multi-view reconstruction using volumetric scene representation. In this paper, we propose a simple approach to estimating visibility based on the current state of a scene which is implicitly represented as the zero level set of a function. Our method can determine the regions of a 3D space visible to several given viewpoints efficiently. Using this visibility method, we also present a new variational formulation for multi-view reconstruction. We cast the multi-view reconstruction problem as an op- timization of a novel energy functional amenable for minimization with an Euler-Lagrange driven evolution. The proposed algorithm has been applied to both synthetic and real datasets with promising results.
1569137068.pdf (293.77 Ko) Télécharger le fichier
inria-00326788 , version 1 (05-10-2008)
  • HAL Id : inria-00326788 , version 1
Liuxin Zhang, Yumo Yang, Yunde Jia. State-Based Visibility for 3D Reconstruction from Multiple Views. Workshop on Multi-camera and Multi-modal Sensor Fusion Algorithms and Applications - M2SFA2 2008, Andrea Cavallaro and Hamid Aghajan, Oct 2008, Marseille, France. ⟨inria-00326788⟩
Collections
M2SFA2
42 Consultations
55 Téléchargements
