Solving the Uniform Density Constraint in a Stochastic Downscaling Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
The present work aims to contribute to the development of a numerical method to compute small scale phenomena in atmospheric models, getting rid of any mesh refinement. In a domain, typically a mesh of a numerical weather prediction model, we simulate some particles that are moved thanks to a Stochastic Lagrangian model adapted from the PDF methods proposed by S.B. Pope. We estimate the Eulerian values of the required fields, thanks to the computation of a local mean value over an ensemble of particles. We are thus using a stochastic particle method. At small scale, our atmospheric model imposes that the mass density is constant in the domain. As a consequence, the particles have to be uniformly distributed at every time step of the particle method. We aim to use D.P. Bertsekas Auction algorithm in order to satisfy this constraint. Naturally, the transport cost will have to be minimum. This is a problem of 3D optimal transport, which is known to be difficult.
proc082407.pdf (441.47 Ko) Télécharger le fichier
inria-00326931 , version 1 (06-10-2008)
Claire Chauvin, Sever Adrian Hirstoaga, Pavla Kabelikova, Antoine Rousseau, Frédéric Bernardin, et al.. Solving the Uniform Density Constraint in a Stochastic Downscaling Model. CEMRACS 2007 - Centre d'Eté Mathématique de Recherche Avancée en Calcul Scientifique, Aug 2007, Marseille, France. pp.97-110, ⟨10.1051/proc:2008032⟩. ⟨inria-00326931⟩
488 Consultations
209 Téléchargements
