Collaborative Filtering inspired from Language Modeling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Geoffray Bonnin
Armelle Brun
Anne Boyer
Recommender systems filter resources for a given user by predicting the most pertinent item given a specific context. This paper describes a new approach of generating suitable recommendations based on the active user's navigation stream. The underlying hypothesis is that the items order in the stream results from the intrinsic logic of the user's behavior. We show similarities between natural language and Internet navigation and put forward navigation specificities. We then design a new model that integrates advantages of statistical language models such as n-grams and triggers to compute recommendations. The resulting Sequence Based Recommender has been tested on Internet navigation artificial corpora.
rspr.pdf (103.01 Ko) Télécharger le fichier
inria-00327070 , version 1 (07-10-2008)
  • HAL Id : inria-00327070 , version 1
Geoffray Bonnin, Armelle Brun, Anne Boyer. Collaborative Filtering inspired from Language Modeling. Proceedings of the First International Conference on the Applications of Digital Information and Web Technologies (ICADIWT 2008), Workshop on Recommender Systems and Personalized Retrieval (RSPR), Aug 2008, Ostrava, Czech Republic. ⟨inria-00327070⟩
142 Consultations
174 Téléchargements
