s'authentifier
version française rss feed
inria-00330024, version 1
Iterative Computations with Ordered Read-Write Locks
Pierre-Nicolas Clauss () a1, Jens Gustedt (Auteur à contacter de préférence) b1
Journal of Parallel and Distributed Computing 70, 5 (2010) 496­-504
Résumé : We introduce the framework of ordered read-write locks, ORWL, that are characterized by two main features: a strict FIFO policy for access and the attribution of access to lock-handles instead of processes or threads. These two properties allow applications to have a controlled pro-active access to resources and thereby to achieve a high degree of asynchronicity between different tasks of the same application. For the case of iterative computations with many parallel tasks which access their resources in a cyclic pattern we provide a generic technique to implement them by means of ORWL. We show that the possible execution patterns for such a system correspond to a combinatorial lattice structure and that this lattice is finite iff the configuration contains a potential deadlock. In addition, we provide efficient algorithms: one that allows for a deadlock-free initialization of such a system and another one for the detection of deadlocks in an already initialized system.
  • a –  Université Henri Poincaré - Nancy I
  • b –  INRIA
  • 1 :  ALGORILLE (INRIA Lorraine - LORIA)
  • INRIA – CNRS : UMR7503 – Université Henri Poincaré - Nancy I – Université Nancy II – Institut National Polytechnique de Lorraine (INPL)
  • Collaboration : Grid'5000
  • Domaine : Informatique/Algorithme et structure de données
    Informatique/Calcul parallèle, distribué et partagé
  • Mots-clés : synchronization – iterative algorithms – read-write locks
  • Référence interne : RR-6685
  • inria-00330024, version 1
  • oai:hal.inria.fr:inria-00330024
  • Contributeur :
  • Soumis le : Lundi 13 Octobre 2008, 22:08:53
  • Dernière modification le : Lundi 23 Avril 2012, 16:35:44
tous les articles de la base du CCSd...
