Wireless Networked Control System using IEEE 802.15.4 with GTS - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
In this paper, the suitability of wireless sensor networks for networked control loop is shown. As the non beacon-enabled mode of IEEE 802.15.4/ZigBee does not ensure the stability for the control loop since non mechanism can prevent the perturbation coming from other applications sharing the same network, we investigate the beacon-enabled mode using the Guaranteed Time Slot (GTS) mechanism and show it is suitable.
WNCS.pdf (924.33 Ko) Télécharger le fichier
inria-00332308 , version 1 (20-10-2008)
inria-00332308 , version 2 (23-10-2008)
  • HAL Id : inria-00332308 , version 2
Najet Boughanmi, Ye-Qiong Song, Eric Rondeau. Wireless Networked Control System using IEEE 802.15.4 with GTS. 2nd Junior Researcher Workshop on Real-Time Computing, JRWRTC 2008, Oct 2008, Rennes, France. pp.21-25. ⟨inria-00332308v2⟩
139 Consultations
377 Téléchargements
