Building certified static analysers by modular construction of well-founded lattices - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
David Pichardie
This paper presents fixpoint calculations on lattice structures as example of highly modular programming in a dependently typed functional language. We propose a library of Coq module functors for constructing complex lattices using efficient data structures. The lattice signature contains a well-foundedness proof obligation which ensures termination of generic fixpoint iteration algorithms. With this library, complex well-foundedness proofs can hence be constructed in a functorial fashion. This paper contains two distinct contributions. We first demonstrate the ability of the recent Coq module system in manipulating alge- braic structures and extracting efficient Ocaml implementations from them. The second contribution is a generic result, based on the constructive notion of accessibility predicate, about preservation of accessibility properties when combining relations.
paper.pdf (191.97 Ko) Télécharger le fichier
inria-00332365 , version 1 (20-10-2008)
  • HAL Id : inria-00332365 , version 1
David Pichardie. Building certified static analysers by modular construction of well-founded lattices. Proc. of the 1st International Conference on Foundations of Informatics, Computing and Software (FICS'08), 2008, Shangai, China. ⟨inria-00332365⟩
130 Consultations
113 Téléchargements
