Improving Energy Conservation Using Bulk Transmission over High-Power Radios in Sensor Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Low power radios, such as the CC2420, have been widely popular with recent sensor platforms. This paper ex- plores the potential for energy savings from adding a high- power, high-bandwidth radio to current sensor platforms. High-bandwidth radios consume more power but signifi- cantly reduce the time for transmissions. Consequently, they offer net savings in total communication energy when there is enough data to offset wake-up energy overhead. The analysis on energy characteristics of several IEEE 802.11 radios show that a feasible crossover point exists (in terms of data size) after which energy savings are possible. Based on this analysis, we present a bulk data transmission proto- col for dual radio systems. The results of simulations and prototype implementation show significant energy savings at the expense of introducing acceptable delay.
3172a801.pdf (318.53 Ko) Télécharger le fichier
inria-00333700 , version 1 (23-10-2008)
  • HAL Id : inria-00333700 , version 1
Cigdem Sengul, Mehedi Bakht, Albert Iii Harris, Tarek Abdelzaher, Robin Kravets. Improving Energy Conservation Using Bulk Transmission over High-Power Radios in Sensor Networks. International Conference on Distributed Computing Systems, Jun 2008, pekin, China. ⟨inria-00333700⟩
250 Consultations
860 Téléchargements
