Spectral Conformal Parameterization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Graphics Forum Année : 2008
Patrick Mullen
  • Fonction : Auteur
  • PersonId : 855051
Yiying Tong
  • Fonction : Auteur
  • PersonId : 855052
Pierre Alliez
Mathieu Desbrun
We present a spectral approach to automatically and efficiently obtain discrete free-boundary conformal parameterizations of triangle mesh patches, without the common artifacts due to positional constraints on vertices and without undue bias introduced by sampling irregularity. High-quality parameterizations are computed through a constrained minimization of a discrete weighted conformal energy by finding the largest eigenvalue/eigenvector of a generalized eigenvalue problem involving sparse, symmetric matrices. We demonstrate that this novel and robust approach improves on previous linear techniques both quantitatively and qualitatively.
SpectralConformal08.pdf (9.68 Mo) Télécharger le fichier
inria-00334477 , version 1 (05-11-2008)
  • HAL Id : inria-00334477 , version 1
Patrick Mullen, Yiying Tong, Pierre Alliez, Mathieu Desbrun. Spectral Conformal Parameterization. Computer Graphics Forum, 2008, Eurographics Symposium on Geometry Processing, 27 (5), pp.1487--1494. ⟨inria-00334477⟩
Collections
INRIA INRIA2
199 Consultations
742 Téléchargements
