Preliminary results for introducing dependent random variables in stochastic feasibility analysis on CAN - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Liliana Cucu
  • Fonction : Auteur
  • PersonId : 844766
We consider periodic and sporadic messages that are scheduled on a Controller Area Network (CAN) bus. We propose a stochastic analysis framework that provides probability distributions of message response times where the arrival of messages are given by independent random variables. This analysis can be extended easily to the case of dependent random variables. We also define the necessary steps to validate such analysis.
article.pdf (70.01 Ko) Télécharger le fichier
inria-00334693 , version 1 (27-10-2008)
Liliana Cucu. Preliminary results for introducing dependent random variables in stochastic feasibility analysis on CAN. 7th IEEE International Workshop on Factory Communication Systems - WFCS'08, Work-in-Progress session, May 2008, Dresden, Germany. pp.271-274, ⟨10.1109/WFCS.2008.4638759⟩. ⟨inria-00334693⟩
73 Consultations
141 Téléchargements
