Formalizing Desargues' theorem in Coq using ranks in Coq - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Formalizing geometry theorems in a proof assistant like Coq is challenging. As emphasized in the literature, the non-degeneracy conditions leads to technical proofs. In addition, when considering higher-dimensions, the amount of incidence relations (e.g. point-line, point-plane, line-plane) induce numerous technical lemmas. In this paper, we present an original approach based on the notion of rank which allows to describe incidence and non-incidence relations such as equality, collinearity and coplanarity homogeneously. It allows to carry out proofs in a more systematic way. To validate this approach, we formalize in Coq (using only ranks) one of the fundamental theorems of the projective space, namely Desargues' theorem.
desargues.pdf (155.51 Ko) Télécharger le fichier
inria-00335719 , version 1 (30-10-2008)
Nicolas Magaud, Julien Narboux, Pascal Schreck. Formalizing Desargues' theorem in Coq using ranks in Coq. 24th Annual ACM Symposium on Applied Computing, Xiao-Shan Gao, Robert Joan-Arinyo, Dominique Michelucci, Mar 2009, Honolulu, United States. pp.1110-1115, ⟨10.1145/1529282.1529527⟩. ⟨inria-00335719⟩
109 Consultations
155 Téléchargements
