Optimal On-line (m,k)-firm Constraint Assignment for Real-time Control Tasks Based on Plant State Information - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Ning Jia
  • Fonction : Auteur
  • PersonId : 831004
Françoise Simonot-Lion
  • Fonction : Auteur
  • PersonId : 830610
Ye-Qiong Song
In this paper, we study the problem of scheduling a set of control tasks. We distinguish three different situations of states of controlled plants: not activated, steady state situation and transient situation. The infinite-horizon and finite-horizon cost functions are respectively used to represent the performance of each control task in last two situations. We propose a scheduling architecture in which, according to the plant state situation, the task handler switches between these two types of performance criterion to determine an on-line (m,k)-constraint based control task scheduling strategy, so that the overall control performance is maintained at a high level in each situation subject to the task schedulability. The approach is exemplified on a set of controllers for different plants.
Automatique
2445.pdf (638.3 Ko) Télécharger le fichier
inria-00335942 , version 1 (03-11-2008)
Flavia Felicioni, Ning Jia, Françoise Simonot-Lion, Ye-Qiong Song. Optimal On-line (m,k)-firm Constraint Assignment for Real-time Control Tasks Based on Plant State Information. 13th IEEE International Conference on Emerging Technologies and Factory Automation - ETFA, Sep 2008, Hamburg, Germany. pp.908-915, ⟨10.1109/ETFA.2008.4638504⟩. ⟨inria-00335942⟩
85 Consultations
152 Téléchargements
