Complexity of Earliest Query Answering with Streaming Tree Automata - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
We investigate the complexity of earliest query answering for n-ary node selection queries defined by streaming tree automata (STAs). We elaborate an algorithm that selects query answers upon reception of the shortest relevant prefix of the input tree on the stream. For queries defined by deterministic STAs, our algorithm runs in polynomial time combined complexity. In the general case, we show that earliest query answering is DEXPTIME-hard (even for n=0) and thus DEXPTIME-complete.
planx08.pdf (197.13 Ko) Télécharger le fichier
inria-00336169 , version 1 (03-11-2008)
  • HAL Id : inria-00336169 , version 1
Olivier Gauwin, Anne-Cécile Caron, Joachim Niehren, Sophie Tison. Complexity of Earliest Query Answering with Streaming Tree Automata. ACM SIGPLAN Workshop on Programming Language Techniques for XML (PLAN-X), Jan 2008, San Francisco, United States. ⟨inria-00336169⟩
142 Consultations
108 Téléchargements
