Walking Your Dog in the Woods in Polynomial Time - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
The Frechet distance between two curves in the plane is the minimum length of a leash that allows a dog and its owner to walk along their respective curves, from one end to the other, without backtracking. We propose a natural extension of Frechet distance to more general metric spaces, which requires the leash itself to move continuously over time. For example, for curves in the punctured plane, the leash cannot pass through or jump over the obstacles (''trees''). We describe a polynomial-time algorithm to compute the homotopic Frechet distance between two given polygonal curves in the plane minus a given set of obstacles, which are either points or polygons.
submission_105.pdf (225.24 Ko) Télécharger le fichier
inria-00336497 , version 1 (04-11-2008)
Erin Wolf Chambers, Eric Colin de Verdire, Jeff Erickson, Sylvain Lazard, Francis Lazarus, et al.. Walking Your Dog in the Woods in Polynomial Time. SoCG 2008 - 24th Annual Symposium on Computational Geometry, Jun 2008, College Park, Maryland, United States. pp.101--109, ⟨10.1145/1377676.1377694⟩. ⟨inria-00336497⟩
241 Consultations
300 Téléchargements
