Embedded harmonic control for trajectory planning in large environments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Bernard Girau
Amine Boumaza
  • Fonction : Auteur
  • PersonId : 830929
Bruno Scherrer
This paper presents an embedded FPGA­based architecture to compute navigation trajectories along a harmonic potential. The goals and obstacles may be changed during computation. Large environments are split into blocks. This approach, together with the use of an increasing precision, enables an optimization of the overall computation time that is theoretically and experimentally studied. Implementation results confirm outstanding speedup factors.
reconfig08.pdf (366.22 Ko) Télécharger le fichier
inria-00337628 , version 1 (07-11-2008)
  • HAL Id : inria-00337628 , version 1
Cesar Torres-Huitzil, Bernard Girau, Amine Boumaza, Bruno Scherrer. Embedded harmonic control for trajectory planning in large environments. International Conference on ReConFigurable Computing and FPGAs - ReConFig 08, Dec 2008, Cancun, Mexico. ⟨inria-00337628⟩
116 Consultations
152 Téléchargements
