Enablers for robust POD models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Physics Année : 2009
This paper focuses on improving the stability as well as the approximation properties of Reduced Order Models (ROM) based on Proper Orthogonal Decomposition (POD). The ROM is obtained by seeking a solution belonging to the POD subspace and that at the same time minimizes the Navier-Stokes residuals. We propose a modified ROM that directly incorporates the pressure term in the model. The ROM is then stabilized making use of a method based on the fine scale equations. An improvement of the POD solution subspace is performed thanks to an hybrid method that couples direct numerical simulations and reduced order model simulations. The methods proposed are tested on the two-dimensional confined square cylinder wake flow in laminar regime.
JCP2008b.pdf (7.51 Mo) Télécharger le fichier
inria-00338203 , version 1 (12-11-2008)
Michel Bergmann, Charles-Henri Bruneau, Angelo Iollo. Enablers for robust POD models. Journal of Computational Physics, 2009, 228 (2), pp.516-538. ⟨10.1016/j.jcp.2008.09.024⟩. ⟨inria-00338203⟩
170 Consultations
575 Téléchargements
