Code Flows: Visualizing Structural Evolution of Source Code - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Graphics Forum Année : 2008
Understanding detailed changes done to source code is of great importance in software maintenance. We present Code Flows, a method to visualize the evolution of source code geared to the understanding of fine and mid-level scale changes across several file versions. We enhance an existing visual metaphor to depict software structure changes with techniques that emphasize both following unchanged code as well as detecting and highlighting important events such as code drift, splits, merges, insertions and deletions. The method is illustrated with the analysis of a real-world C++ code system.
paperEurovisAlexDavid.pdf (1.05 Mo) Télécharger le fichier
inria-00338601 , version 1 (13-11-2008)
  • HAL Id : inria-00338601 , version 1
Alexandru C Telea, David Auber. Code Flows: Visualizing Structural Evolution of Source Code. Computer Graphics Forum, 2008, pp.831-938. ⟨inria-00338601⟩
133 Consultations
992 Téléchargements
