s'authentifier
version française rss feed
inria-00338701, version 1
Computing Largest Circles Separating Two Sets of Segments
Jean-Daniel Boissonnat () 1, Jurek Czyzowicz a2, Olivier Devillers () 1, Jorge Urrutia 3, Mariette Yvinec () 1
International Journal of Computational Geometry & Applications 10 (2000) 41--54
Résumé : A circle C separates two planar sets if it encloses one of the sets and its open interior disk does not meet the other set. A separating circle is a largest one if it cannot be locally increased while still separating the two given sets. An Theta(n log n) optimal algorithm is proposed to find all largest circles separating two given sets of line segments when line segments are allowed to meet only at their endpoints. In the general case, when line segments may intersect Omega(n^2) times, our algorithm can be adapted to work in O(n alpha(n) log n) time and O(n alpha(n)) space, where alpha(n) represents the extremely slowly growing inverse of the Ackermann function.
  • Domaine : Informatique/Géométrie algorithmique
  • inria-00338701, version 1
  • oai:hal.inria.fr:inria-00338701
  • Contributeur :
  • Soumis le : Vendredi 14 Novembre 2008, 09:43:24
  • Dernière modification le : Vendredi 14 Novembre 2008, 10:08:13
tous les articles de la base du CCSd...
