Histogram of Radon Transform. A useful descriptor for shape retrieval - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
In this paper we present a new descriptor based on the Radon transform. We propose a histogram of the Radon transform, called HRT, which is invariant to common geometrical transformations. For black and white shapes, the HRT descriptor is a histogram of shape lengths at each orientation. The experimental results, defined on different databases and compared with several well-known descriptors, show the robustness of our method.
paper449.pdf (896.24 Ko) Télécharger le fichier
inria-00339116 , version 1 (16-11-2008)
  • HAL Id : inria-00339116 , version 1
Salvatore Tabbone, Oriol Ramos Terrades, Sabine Barrat. Histogram of Radon Transform. A useful descriptor for shape retrieval. 19th International Conference on Pattern Recognition - ICPR 2008, Dec 2008, Tampa, United States. ⟨inria-00339116⟩
183 Consultations
642 Téléchargements
