Local time stepping and discontinuous Galerkin methods for symmetric first order hyperbolic systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational and Applied Mathematics Année : 2008
We present a new non conforming space-time mesh refinement method for symmetric first order hyperbolic system. This method is based on the one hand on the use of a conservative higher order discontinuous Galerkin approximation for space discretization and a finite difference scheme in time, on the other hand on appropriate discrete transmission conditions between the grids. We use a discrete energy technique to drive the construction of the matching procedure between the grids and guarantee the stability of the method.
ej_jcam08.pdf (587.44 Ko) Télécharger le fichier
inria-00339912 , version 1 (19-11-2008)
  • HAL Id : inria-00339912 , version 1
Abdelaâziz Ezziani, Patrick Joly. Local time stepping and discontinuous Galerkin methods for symmetric first order hyperbolic systems. Journal of Computational and Applied Mathematics, 2008. ⟨inria-00339912⟩
262 Consultations
222 Téléchargements
