Passivity-based switching control of flexible-joint complementarity mechanical systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
In this study one considers the tracking control problem of a class of nonsmooth Lagrangian systems with flexible joints and subject to frictionless unilateral constraints. The task under consideration consists of a succession of free-motion and constrained-motion phases. A particular attention is paid to impacting and detachment phases. A passivity-based switching controller that allows to extend the stability analysis described in our previous works to the case of systems with lumped flexibilities, is proposed. Numerical tests show the effectiveness of the controller.
RR-6739.pdf (3.03 Mo) Télécharger le fichier
inria-00342292 , version 1 (27-11-2008)
  • HAL Id : inria-00342292 , version 1
Irinel-Constantin Morarescu, Bernard Brogliato, Said Haad. Passivity-based switching control of flexible-joint complementarity mechanical systems. [Research Report] RR-6739, INRIA. 2008, pp.41. ⟨inria-00342292⟩
301 Consultations
395 Téléchargements
