Application of Cagniard de Hoop Method to the Analysis of Perfectly Matched Layers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
We show how Cagniard de Hoop method can be used, first to obtain error estimates for the Perfectly Matched Layers in acoustics (PML), then to understand the instabilities of the PML when applied to aeroacousics. The principle of the methods consists in applying to the equations a Laplace transform in time and a Fourier transform in one space variable to obtain an ordinary differential equation which can be explicitely solved.
diazjoly.pdf (535.89 Ko) Télécharger le fichier
inria-00343016 , version 1 (28-11-2008)
  • HAL Id : inria-00343016 , version 1
Julien Diaz, Patrick Joly. Application of Cagniard de Hoop Method to the Analysis of Perfectly Matched Layers. 3rd IFAC Workshop on Fractional Differentiation and its Applications, Nov 2008, Ankara, Turkey. ⟨inria-00343016⟩
229 Consultations
824 Téléchargements
