An Algorithm for File Transfer Scheduling in Grid Environments
This paper addresses the data transfer scheduling problem for Grid environments, presenting a centralized scheduler developed with dynamic and adaptive features. The algorithm offers a reservation system for user transfer requests that allocates them transfer times and bandwidth, according to the network topology and the constraints the user specified for the requests. This paper presents the projects related to the data transfer field, the design of the framework for which the scheduler was built, the main features of the scheduler, the steps for transfer requests rescheduling and two tests that illustrate the system's behavior for different types of transfer requests.
FileTransferScheduler.pdf (405.17 Ko)
Télécharger le fichier
related_materials_2nd_author.zip (25.6 Mo)
Format : Autre
