Peer-to-peer Collaboration over XML Documents - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Gérald Oster
Existing solutions for the collaboration over XML documents are limited to a centralised architecture. In this paper we propose an approach for peer-to-peer collaboration over XML documents where users can work off-line on their document replica and synchronise in an ad-hoc manner with other users. Our algorithm for maintaining consistency over XML documents recursively applies the tombstone operational transformation approach over the document levels.
Autre [cs.OH]
IgnatCDVE08.pdf (90.45 Ko) Télécharger le fichier
inria-00343815 , version 1 (02-12-2008)
Claudia-Lavinia Ignat, Gérald Oster. Peer-to-peer Collaboration over XML Documents. International Conference on Cooperative Design, Visualization and Engineering - CDVE 2008, Sep 2008, Mallorca, Spain. pp.66-73, ⟨10.1007/978-3-540-88011-0⟩. ⟨inria-00343815⟩
90 Consultations
193 Téléchargements
