Dynamic Scheduling for sparse direct Solver on NUMA architectures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Over the past few years, parallel sparse direct solvers made significant progress and are now able to efficiently work on problems with several millions of equations. This paper presents some improvements on our sparse direct solver PaStiX1 for distributed Non-Uniform Memory Access architectures. We show results on two preliminary works: a memory allocation scheme more adapted to these architectures and a better overlap of communication by computation. We also present a dynamic scheduler that takes care of memory affinity and data locality.
para08.pdf (274.59 Ko) Télécharger le fichier
inria-00344026 , version 1 (16-01-2009)
  • HAL Id : inria-00344026 , version 1
Mathieu Faverge, Pierre Ramet. Dynamic Scheduling for sparse direct Solver on NUMA architectures. PARA'08, May 2008, Trondheim, Norway. ⟨inria-00344026⟩
152 Consultations
147 Téléchargements
