Exploiting Weak Dependencies in Tree-based Search - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Alejandro Arbelaez
  • Fonction : Auteur
  • PersonId : 856329
Youssef Hamadi
  • Fonction : Auteur
  • PersonId : 840368
In this work, our objective is to heuristically discover a simplified form of functional dependencies between variables called weak dependencies. Once discovered, these relations are used to rank the variables. Our method shows that these relations can be detected with some acceptable overhead during constraint propagation. More precisely, each time a variable y gets instantiated as a result of the instantiation of x, a weak dependency (x,y) is recorded. As a consequence, the weight of x is raised, and the variable becomes more likely to be selected by the variable ordering heuristic. Experiments on a large set of problems show that on the average, the search trees are reduced by a factor 3 while runtime is decreased by 31% when compared against dom-wdeg, one of the best dynamic variable ordering heuristic.
Autre [cs.OH]
SAC-functdep.pdf (138.84 Ko) Télécharger le fichier
inria-00344179 , version 1 (03-12-2008)
  • HAL Id : inria-00344179 , version 1
Alejandro Arbelaez, Youssef Hamadi. Exploiting Weak Dependencies in Tree-based Search. 24th Annual ACM Symposium on Applied Computing, Mar 2009, Honolulu, United States. ⟨inria-00344179⟩
Collections
INRIA
144 Consultations
319 Téléchargements
