Interval Arithmetic Yields Efficient Dynamic Filters for Computational Geometry - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Applied Mathematics Année : 2001
We discuss floating-point filters as a means of restricting the precision needed for arithmetic operations while still computing the exact result. We show that interval techniques can be used to speed up the exact evaluation of geometric predicates and describe an efficient implementation of interval arithmetic that is strongly influenced by the rounding modes of the widely used IEEE 754 standard. Using this approach we engineer an efficient floating-point filter for the computation of the sign of a determinant that works for arbitrary dimensions. We validate our approach experimentally, comparing it with other static, dynamic and semi-static filters.
interval_journal-1.pdf (177.76 Ko) Télécharger le fichier
inria-00344281 , version 1 (04-12-2008)
  • HAL Id : inria-00344281 , version 1
Hervé Brönnimann, Christoph Burnikel, Sylvain Pion. Interval Arithmetic Yields Efficient Dynamic Filters for Computational Geometry. Discrete Applied Mathematics, 2001, 109, pp.25-47. ⟨inria-00344281⟩
Collections
INRIA INRIA2
69 Consultations
586 Téléchargements
