An Adaptable and Extensible Geometry Kernel - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computational Geometry Année : 2007
Geometric algorithms are based on geometric objects such as points, lines and circles. The term kernel refers to a collection of representations for constant-size geometric objects and operations on these representations. This paper describes how such a geometry kernel can be designed and implemented in C++, having special emphasis on adaptability, extensibility and efficiency. We achieve these goals following the generic programming paradigm and using templates as our tools. These ideas are realized and tested in CGAL, the Computational Geometry Algorithms Library, see http://www.cgal.org/.
kernel.pdf (251.01 Ko) Télécharger le fichier
inria-00344363 , version 1 (04-12-2008)
Susan Hert, Michael Hoffmann, Lutz Kettner, Sylvain Pion, Michael Seel. An Adaptable and Extensible Geometry Kernel. Computational Geometry, 2007, Special Issue on CGAL, 38 (1-2), pp.16-36. ⟨10.1016/j.comgeo.2006.11.004⟩. ⟨inria-00344363⟩
Collections
INRIA INRIA2
265 Consultations
369 Téléchargements
