Formal certification of arithmetic filters for geometric predicates - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
Sylvain Pion
Floating-point arithmetic provides a fast but inexact way of computing geometric predicates. In order for these predicates to be exact, it is important to rule out all the numerical situations where floating-point computations could lead to wrong results. Taking into account all the potential problems is a tedious work to do by hand. We study in this paper a floating-point implementation of a filter for the orientation-2 predicate, and how a formal and partially automatized verification of this algorithm avoided many pitfalls. The presented method is not limited to this particular predicate, it can easily be used to produce correct semi-static floating-point filters for other geometric predicates.
IMACS_05_FPgeo.pdf (180.95 Ko) Télécharger le fichier
inria-00344518 , version 1 (05-12-2008)
  • HAL Id : inria-00344518 , version 1
Guillaume Melquiond, Sylvain Pion. Formal certification of arithmetic filters for geometric predicates. 17th IMACS World Congress, 2005, Paris, France. ⟨inria-00344518⟩
377 Consultations
237 Téléchargements
