s'authentifier
version française rss feed
inria-00345283, version 1
Polyomino-Based Digital Halftoning
David Vanderhaeghe (Auteur à contacter de préférence) a12, Victor Ostromoukhov 3
IADIS International Conference on Computer Graphics and Visualization 2008 (2008)
Résumé : In this work, we present a new method for generating a threshold structure. This kind of structure can be advantageously used in various halftoning algorithms such as clustered-dot or dispersed-dot dithering, error diffusion with threshold modulation, etc. The proposed method is based on rectifiable polyominoes -- a non-periodic hierarchical structure, which tiles the Euclidean plane with no gaps. Each polyomino contains a fixed number of discrete threshold values. Thanks to its inherent non-periodic nature combined with off-line optimization of threshold values, our polyomino-based threshold structure shows blue-noise spectral properties. The halftone images produced with this threshold structure have high visual quality. Although the proposed method is general, and can be applied on any polyomino tiling, we consider one particular case: tiling with G-hexominoes. We compare our polyomino-based threshold structure with the best known state-of-the-art methods for generation threshold matrices, and conclude considerable improvement achieved with our method. More at http://artis.imag.fr/Publications/2008/VO08/
  • Domaine : Informatique/Synthèse d'image et réalité virtuelle
  • Mots-clés : Halftoning – Tiling – Polyomino – Dithering
  • inria-00345283, version 1
  • oai:hal.inria.fr:inria-00345283
  • Contributeur :
  • Soumis le : Lundi 8 Décembre 2008, 18:27:44
  • Dernière modification le : Mardi 10 Avril 2012, 09:15:55
tous les articles de la base du CCSd...
