inria-00345285, version 1
Sample-based Visibility for Soft Shadows Using Alias-free Shadow Maps
Erik Sintorn 1Elmar Eisemann
2, 3Ulf Assarsson 1
Computer Graphics Forum (Proceedings of the Eurographics Symposium on Rendering 2008) 27, 4 (2008) 1285--1292
Résumé : This paper introduces an accurate real-time soft shadow algorithm that uses sample based visibility. Initially, we present a GPU-based alias-free hard shadow map algorithm that typically requires only a single render pass from the light, in contrast to using depth peeling and one pass per layer. For closed objects, we also suppress the need for a bias. The method is extended to soft shadow sampling for an arbitrarily shaped area-/volumetric light source using 128-1024 light samples per screen pixel. The alias-free shadow map guarantees that the visibility is accurately sampled per screen-space pixel, even for arbitrarily shaped (e.g. non-planar) surfaces or solid objects. Another contribution is a smooth coherent shading model to avoid common light leakage near shadow borders due to normal interpolation. More at http://artis.imag.fr/Publications/2008/SEA08
- 1 : Chalmers University of Technology (Chalmers)
- Chalmers University of Technology
- 2 : Laboratoire Jean Kuntzmann (LJK)
- CNRS : UMR5224 – Université Joseph Fourier - Grenoble I – Université Pierre Mendès-France - Grenoble II – Institut Polytechnique de Grenoble - Grenoble Institute of Technology
- 3 : ARTIS (INRIA Grenoble Rhône-Alpes / LJK Laboratoire Jean Kuntzmann)
- CNRS : FR71 – INRIA – Laboratoire Jean Kuntzmann – CNRS : UMR5224 – Université Joseph Fourier - Grenoble I – Institut National Polytechnique de Grenoble (INPG)
- Domaine : Informatique/Synthèse d'image et réalité virtuelle
- Mots-clés : Shadows – alias-free – GPU
- inria-00345285, version 1
- http://hal.inria.fr/inria-00345285
- oai:hal.inria.fr:inria-00345285
- Contributeur : Nicolas Holzschuch
- Soumis le : Lundi 8 Décembre 2008, 18:25:08
- Dernière modification le : Vendredi 2 Mars 2012, 11:44:36
Documents associés
Exporter
