An end-to-end administrative document analysis system - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Hatem Hamza
  • Fonction : Auteur
  • PersonId : 830528
Yolande Belaïd
Abdel Belaïd
  • Fonction : Auteur
  • PersonId : 856537
This paper presents an end-to-end administrative document analysis system. This system uses case-based reasoning in order to process documents from known and unknown classes. For each document, the system retrieves the nearest processing experience in order to analyze and interpret the current document. When a complete analysis is done, this document needs to be added to the document database. This requires an incremental learning process in order to take into account every new information, without losing the previous learnt ones. For this purpose, we proposed an improved version of an already existing neural network called Incremental Growing Neural Gas. Applied on documents learning and classification, this neural network reaches a recognition rate of 97.63%.
PDF_editeur.pdf (882.65 Ko) Télécharger le fichier
inria-00346019 , version 1 (12-12-2008)
  • HAL Id : inria-00346019 , version 1
Hatem Hamza, Yolande Belaïd, Abdel Belaïd, Bidyut B. Chaudhuri. An end-to-end administrative document analysis system. The Eighth IAPR International Workshop on Document Analysis Systems - DAS 2008, Sep 2008, Nara, Japan. pp.175-182. ⟨inria-00346019⟩
141 Consultations
400 Téléchargements
