s'authentifier
version française rss feed
inria-00346857, version 1
Analysis of Failure Correlation in Peer-to-Peer Storage Systems
Olivier Dalle () 1, Frédéric Giroire (Auteur à contacter de préférence) 1, Julian Monteiro 1, Stéphane Pérennes () 1
N° RR-6771 (2008)
Résumé : In this paper, we propose and study analytical models of self-repairing peer-to-peer storage systems subject to failures. The failures correspond to the simultaneous loss of multiple data blocks due to the definitive loss of a peer (or following a disk crash). In the system we consider that such failures happen continuously, hence the necessity of a self-repairing mechanism (data are written once for ever). We show that, whereas stochastic models of independent failures similar to those found in the literature give a correct approximation of the average behavior of real systems, they fail to capture their variations (e.g. in bandwidth needs). We propose to solve this problem using a new stochastic model based on a fluid approximation and we give a characterization of the behavior of the system according to this model (expectation and standard deviation). This new model is validated using comparisons between its theoretical behavior and computer simulations.
  • Domaine : Informatique/Réseaux et télécommunications
  • Mots-clés : P2P storage system – failure correlation – performance evaluation – data durability – Markov chain models – fluid models.
  • Référence interne : RR-6771
  • inria-00346857, version 1
  • oai:hal.inria.fr:inria-00346857
  • Contributeur :
  • Soumis le : Vendredi 12 Décembre 2008, 14:09:00
  • Dernière modification le : Jeudi 18 Décembre 2008, 10:54:55
tous les articles de la base du CCSd...
