The Architecture of the XtreemOS Grid Checkpointing Service - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
The EU-funded XtreemOS project implements a grid operating system (OS) transparently exploiting distributed resources through the SAGA and POSIX interfaces. XtreemOS uses an integrated grid checkpointing service (XtreemGCP) for implementing migration and fault tolerance. Checkpointing and restarting applications in a grid requires saving and restoring applications in a distributed heterogeneous environment. The latter may spawn millions of grid nodes using different system-specific checkpointers saving and restoring application and kernel data structures on a grid node. In this paper we present the architecture of the XtreemGCP service integrating existing checkpointing solutions. Our architecture is open to support different checkpointing strategies that can be adapted according to evolving failure situations or changing application requirements. We propose to bridge the gap between grid semantics and system-specific checkpointers by introducing a common kernel checkpointer API that allows using different checkpointers in a uniform way. Furthermore, we discuss other grid related checkpointing issues including resource conflicts during restart, security, and checkpoint file management. Although this paper presents a solution within the XtreemOS context it can be applied to any other grid middleware or distributed OS, too.
RR-6772.pdf (311.68 Ko) Télécharger le fichier
inria-00346955 , version 1 (12-12-2008)
  • HAL Id : inria-00346955 , version 1
John Mehnert-Spahn, Thomas Ropars, Michael Schoettner, Christine Morin. The Architecture of the XtreemOS Grid Checkpointing Service. [Research Report] RR-6772, INRIA. 2008, pp.19. ⟨inria-00346955⟩
301 Consultations
517 Téléchargements
