inria-00347048, version 2
A Volterra filter for neuronal spike detection
(2008)
Résumé : The spike detection problem is cast into a delay estimation. Using elementary operational calculus, we obtain an explicit characterization of the spike locations, in terms of short time window iterated integrals of the noisy signal. From this characterization, we derive a joint spike detection and localization system where the decision function is implemented as the output of a digital Volterra filter. Simulation results using experimental data shows that the method compares favorably with one of the most successful one in the litterature.
- 1 : UFR de Mathématiques et Informatique [Paris V]
- Université Paris V - Paris Descartes
- 2 : ALIEN (INRIA Saclay - Ile de France)
- INRIA – Polytechnique - X – Ecole Centrale de Lille – CNRS : UMR8146
- Domaine : Informatique/Traitement du signal et de l'image
Sciences de l'ingénieur/Traitement du signal et de l'image - Versions disponibles : v1 (13-12-2008) v2 (05-03-2012)
- inria-00347048, version 2
- http://hal.inria.fr/inria-00347048
- oai:hal.inria.fr:inria-00347048
- Contributeur : Laurence Farhi
- Soumis le : Lundi 5 Mars 2012, 16:48:09
- Dernière modification le : Lundi 5 Mars 2012, 16:56:02
Documents associés
Exporter
