Homotopy in Cat via Paths and the Fundamental Groupoid of a Category - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
We construct an endofunctor of paths in the category of small category and show how to construct the standard homotopy invariants from it. We give a novel proof that the fundamental groupoid of a category is its associated universal groupoid.
HomotCat.pdf (283.69 Ko) Télécharger le fichier
inria-00347424 , version 1 (15-12-2008)
  • HAL Id : inria-00347424 , version 1
François Lamarche. Homotopy in Cat via Paths and the Fundamental Groupoid of a Category. [Research Report] 2008. ⟨inria-00347424⟩
148 Consultations
149 Téléchargements
