s'authentifier
version française rss feed
inria-00348359, version 1
Fitting 3d models on central catadioptric images
Eric Marchand () a1, François Chaumette () a1
IEEE Int. Conf. on Robotics and Automation, ICRA'07 (2007) 52-58
Résumé : Increasing the field of view of camera is an important issue practical in robot vision. one solution is to consider catadioptric camera that allows a 360o field of view. in this paper we propose a 3d model tracking algorithm that allows a fast and reliable tracking of 3d objects within central catadioptric images. the proposed approach relies on the virtual visual servoing approach. all the modeling aspects have been reconsidered to consider the projection model. results show the method to be robust and efficient.
  • Domaine : Informatique/Robotique
  • inria-00348359, version 1
  • oai:hal.inria.fr:inria-00348359
  • Contributeur :
  • Déposé pour le compte de :
  • Soumis le : Jeudi 18 Décembre 2008, 16:26:19
  • Dernière modification le : Lundi 5 Octobre 2009, 15:06:09
tous les articles de la base du CCSd...
