Grimage: 3D modeling for remote collaboration and telepresence - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Real-time multi-camera 3D modeling provides full-body geometric and photometric data on the objects present in the acquisition space. It can be used as an input device for rendering textured 3D models, and for computing interactions with virtual objects through a physical simulation engine. In this paper we present a work in progress to build a collaborative environment where two distant users, each one 3D modeled in real-time, interact in a shared virtual world.
p299-petit.pdf (953.02 Ko) Télécharger le fichier
Format : Figure, Image
inria-00349127 , version 1 (23-12-2008)
Benjamin Petit, Jean-Denis Lesage, Jean-Sébastien Franco, Edmond Boyer, Bruno Raffin. Grimage: 3D modeling for remote collaboration and telepresence. VRST 2008 - ACM symposium on Virtual reality software and technology, Oct 2008, Bordeaux, France. pp.299-300, ⟨10.1145/1450579.1450662⟩. ⟨inria-00349127⟩
541 Consultations
635 Téléchargements
