Identification of generalized impedance boundary conditions in inverse scattering problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
In the context of scattering problems in the harmonic regime, we consider the problem of identification of some Generalized Impedance Boundary Conditions (GIBC) at the boundary of an object (which is supposed to be known) from far field measurements associated with a single incident plane wave at a fixed frequency. The GIBCs can be seen as approximate models for thin coatings, corrugated surfaces or highly absorbing media. After pointing out that uniqueness does not hold in the general case, we propose some additional assumptions for which uniqueness can be restored. We also consider the question of stability when uniqueness holds. We prove in particular Lipschitz stability when the impedance parameters belong to a compact set. We also extend local stability results to the case of back-scattering data.
RR-6786.pdf (306.82 Ko) Télécharger le fichier
inria-00349258 , version 1 (26-12-2008)
inria-00349258 , version 2 (11-02-2009)
  • HAL Id : inria-00349258 , version 2
Laurent Bourgeois, Houssem Haddar. Identification of generalized impedance boundary conditions in inverse scattering problems. [Research Report] RR-6786, INRIA. 2008, pp.27. ⟨inria-00349258v2⟩
378 Consultations
371 Téléchargements
